查看: 3|回复: 0
U4GM on PoE Atlas Regions and Early Mapping
发表于 3 小时前 | 显示全部楼层 |阅读模式
PoE early mapping works best when you reserve currency for playable maps and choose Atlas mechanics your build can finish before committing more Threads of Creation. While some players consider POE currency for their early gearing plans, a protected map reserve remains the safer priority.
Build a reserve before the Atlas
Keep Wisdom, Portal, Transmutation, Alteration, and Alchemy currency available through the campaign, along with a small Chaos reserve. Treat the early map reserve separately: it needs to cover rolling a workable set of maps once the Atlas opens.
A campaign unique can be tempting, but spending the map reserve on it can leave you short when you reach the Atlas. Buy or craft only what your character needs to keep progressing; leave expensive endgame pieces for later.
Standard characters and their wealth do not transfer into a new league. Practice a skill route there if useful, but make your actual budget around what the new league character earns.
Pick regions and mechanics your build can clear
The supplied expansion details describe a rebuilt Atlas passive tree with mechanic regions. Choose one or two mechanics that suit your defenses and damage instead of spreading early investment across every option.
Threads of Creation replace Scarabs in the Map Device and add a random reward layer to a selected mechanic. The described primary mechanics are Abyss, Blight, Legion, Breach, Incursion, Betrayal, Bestiary, Expedition, Ultimatum, and Ritual.
Use the Map Device to review your selected mechanics and Thread setup before opening a map. Threads persist between maps and draw from the stash, so check the setup when changing your plan rather than assuming every map needs a fresh placement.
Up to eight Threads can be spent on one mechanic, while finishing the Atlas questline unlocks three mechanic slots on a map. Start with a low Thread commitment: spending heavily on an encounter you cannot finish wastes resources without fixing the build.
Budget around boss fights and visible loot
Fates increase the danger and potential rewards of area bosses, with up to three invoked on one boss. Begin with softer combinations and add danger only after your defenses hold up; stacking harsh Fates early can end a run before the rewards arrive.
Fate-empowered bosses can drop Viscera for the Wickerman, which has head, arm, body, and leg slots. Matching or duplicate Fates have been described as improving rewards, but their added risk makes them a poor first expense for a fragile character.
Review your loot filter before mapping. The supplied details say Magic and Rare items can drop with visible tiers, so a filter that hides every item of those rarities could also hide useful bases. Keep currency and high-tier bases readable, and check the filter against the final game details before relying on it.
Check uncertain details before spending
The supplied launch time is 11:00 PST on November 13, equivalent to 19:00 UTC and 03:00 the next day in Asia/Shanghai. Treat that date and the described expansion systems as unconfirmed until the final game information is available; no exact Thread drop rates or Viscera values are provided here.
Before opening your first map, check the Map Device setup, review your filter, and count the Alchemy and Chaos currency you have kept aside. Treat POE orbs as a separate spending decision, not a substitute for checking that your character can finish the selected encounters.
GMT+8, 2026-11-11 21:17 , Processed in 0.012138 second(s), 20 queries .
