查看: 8|回复: 0
ARC Raiders Limited PvE Mode - No PvP Damage | Buy Cheap Items on IGGM
发表于 昨天 10:13 | 显示全部楼层 |阅读模式
ARC Raiders is about to launch a highly anticipated test for its new PvE mode. The most significant change in this test is the removal of friendly fire/player-versus-player damage mechanics. On this perilous alien map, you no longer need to worry about ambushes from other players; all threats come from AI-controlled ARC mechanical units.
For more details, please view the related post: ARC Raiders Will Introduce a Limited-Time PvE Mode | Matchmaking, Loot Changes, and Economic Risks
The announcement sparked lively discussion within the player community; while many felt this PvE mode was long overdue, there remains great enthusiasm for this limited-time test.
During initial research, the development team discovered that a large number of players preferred cooperative gameplay. Rather than the tense, high-stakes PvPvE combat, they wanted to team up with others to focus on fighting ARC enemies, completing missions, gathering supplies, and extracting safely.
Based on this extensive player feedback, the developers decided to launch this limited-time PvE test to gather data on queue times, matchmaking, and the in-game economy, which will help determine whether to make the mode a permanent feature.
The two modes also feature different reward structures to balance risk and reward. In PvE mode, the value of dropped ARC Raiders items is relatively lower, whereas the traditional PvPvE mode offers higher base rewards. This design satisfies casual players who want a secure environment for gathering supplies while preserving the option for hardcore players to pursue high-risk, high-reward gameplay.
This test is available for a limited time only, so players eager to experience pure cooperative combat and stress-free map scavenging should not miss this opportunity.
However, even without the threat of ambushes from other players, the PvE mode is far from a mindless hack-and-slash experience. The various ARC mechanical enemies found across the map feature distinct attack patterns; some elite ARC units boast heavy armor and deal massive burst damage.
To successfully complete missions and extract safely, having the right gear, consumables, and various ARC Raiders items is essential. If your inventory is ill-equipped, facing swarms of ARC units can easily lead to defeat mid-mission, causing you to lose all the hard-earned supplies you’ve scavenged.
Many players intend to use this PvE test to familiarize themselves with the map and practice the combat rhythm against the ARC, but gathering ARC Raiders items from scratch requires a significant time investment. Repeatedly entering the map and failing to extract results in the loss of all carried gear; this tedious accumulation process can be exhausting and detract from the enjoyment of the PvE mode. Amassing sufficient armor, ammunition, medkits, and weapon attachments often requires multiple successful extractions.
IGGM offers an easy solution for ARC Raiders players:
Whether you are gearing up for this PvE test or continuing to play classic PvPvE matches, you can find all the items you need here. We provide a one-stop shop for everything from armor and powerful primary weapons to emergency medical supplies, ammo, and mission-critical items. Skip the risky runs and extraction gambles - get the ARC Raiders items you need immediately, start the match with strong combat capabilities, and focus on enjoying the new PvE mode.
IGGM prioritizes account security and employs safe delivery methods to minimize transaction risks. We maintain ample stock and ensure rapid delivery after orders are placed, so you won't face long waits due to shortages.
Multilingual customer support is available around the clock; whether you have questions before ordering or encounter issues during delivery, help is always just a message away. The ordering process is simple and intuitive, with a wide range of payment options, making it easy for both new and veteran players to get started.
This PvE test - featuring no player-versus-player damage - is a rare opportunity to experience pure cooperative combat against the ARC. Team up with friends and explore the planet's map and complete mission objectives without the constant threat of ambushes from other players.
Stock up on ARC Raiders items in advance on IGGM to boost your survivability and significantly increase your extraction success rate, allowing you to fully enjoy the unique fun of the game's all-new PvE gameplay.
Complete Guide to Buy ARC Raiders Items on IGGM:
How to buy ARC Raiders items on IGGM?
1. Browse the ARC Raiders item categories or use the search bar to find the items you want, then add them to your cart.
2. Enter your account and delivery details carefully. Double-check all information to prevent any mistakes.
3. Pick your favourite payment option and hit "Pay Now" to finish checkout.
4. Grab an 8% discount with promo code: ARC8
Note: Before placing an order, if you want to know about accounts, points, VIP perks, affiliate programs, order processing or customer support? Please view our IGGM FAQs.
Safe Trading Guidelines for Items
- Make sure you submit your correct Embark ID.
- Our team will send you a group invite. Once we drop the items in-game, move them into your Safe Pocket Slots right away. We cannot take responsibility for lost items if you fail to store them in the safe box.
- Avoid bringing any of your high-value belongings into the game during the trade.
Where to Locate Your Embark ID
1. Launch ARC Raiders and stay on the main menu.
2. Tap the "+" button to open the friends and party menu.
3. Click Manage Embark ID at the bottom left corner.
4. Your profile page will display your Embark display name and ID. You can copy your ID from this page.
Finally, I suggest that you add IGGM as your Google preferred source to catch restock updates for newly released blueprints, limited discount codes, and the latest game patch & Trial guides.
GMT+8, 2026-9-29 07:36 , Processed in 0.013090 second(s), 20 queries .
